Fecha actual Sab May 08, 2021 11:06 am
Pais: Argentina
Level: 69
HP: 6908 / 26572
6908 / 26572
MP: 12687 / 12687
12687 / 12687
EXP: 12313 / 12634
12313 / 12634
