Fecha actual Mar Sep 26, 2023 12:15 am
Pais: Argentina
Level: 69
HP: 5845 / 26572
5845 / 26572
MP: 12687 / 12687
12687 / 12687
EXP: 12368 / 12634
12368 / 12634
