Fecha actual Vie Abr 25, 2025 10:02 pm
Pais: Argentina
Level: 69
HP: 5314 / 26572
5314 / 26572
MP: 12687 / 12687
12687 / 12687
EXP: 12404 / 12634
12404 / 12634
